Skin Type (Updated for v1.1)
The Skin Type block lists all available skin types of Headshot. To put it in simple words, a skin type is one of the widely used presets of Skin Settings options. Users can quickly create or mimic specific face characteristic without digging into the complicated bits and bobs. Each button represents a combination of textures and masks which form certain skin features.
The buttons are identical with the ones on Generate Character panel. You may switch to another skin type at any time despite the earlier choice.
The table below shows the results of each skin type applied onto a Headshot generated head for easier observation:
- No Mask
- Clean Soft
No Mask
Clean Soft
- Clean Rough
No Mask
Clean Rough
- Scalp
No Mask
Scalp
- Beard and Scalp
No Mask
Beard and Scalp
- Contour
No Mask
Contour
- Sensitive
No Mask
Sensitive
- Old Female
No Mask
Old Female
- Old Male
No Mask
Old Male
- Very Old
No Mask
Very Old
Pro Mode is designed for generating a high quality front face map and do not deal with the textures of the side and back by default. Texture distortion on both sides and the back of the head is expected if the option No Mask is applied. All other skin type options fix the distorted part of the image with designated skin feature base on the Blend Mask in Skin Settings.
