Installing "iClone Live Link Plug-in" into Unreal
There are two methods to install iClone Live Link Plug-in into Unreal. You can either install via the Reallusion Hub / download site, or install via the Unreal Epic Games Marketplace.
Installing via Reallusion Hub or Download Site
- Install Unreal Live Link Plug-in for iClone.
- Open the Shared Plugins folder in which the iClone Live Link source files for Unreal are stored: C:\Program Files\Reallusion\Shared Plugins\iClone Live Link for Unreal. You will see iClone Live Link Plug-in for Unreal 4.23, iClone Live Link Plug-in for Unreal 4.24 and iClone Live Link Plug-in for Unreal 4.25 folders.
- Open either one of the folders in accordance with the version of your Unreal (in this case, 4.22).
Keep in mind that the file structure in these 3 folders are identical.
Note:To find out the Unreal Engine version or your Unreal Project version, open the Epic Game Launcher and you can find them in the Library tab.
- Copy the Plugins folder.
- Paste this folder into the Unreal specific folders in two tiers:
- Unreal Engine tier: Paste the folder into the Unreal installed folder C:\Program Files\Epic Games\UE_4.25\Engine.
This step ensures that each project will share and use the same plug-in.
- Project tier: Paste the folder into the Unreal project folder.
This step ensures that each project can use different but correct versions of iClone Live Link plug-in.
- Launch Unreal and you can see the iClone Live Link Plugin on the toolbar.
Note:If you don't see the button on the toolbar, then go to the Plugins panel and search for the Live Link plugins in the Reallusion node. Activate the Enabled checkbox as shown below:
In the Animation node, enable the Live Link plugin as well.
Installing via Epic Games Marketplace
- Launch the Epic Games Launcher and switch to the Marketplace tab.
- Type in iClone Unreal Live Link into the search field and you will see the page for the plug-in.
- Scroll down and click the Install to Engine button in this page.
- Pick your target engine version and click the Install button.
- Activate the check box for the License Agreement and click the Accept button.
- Wait for the installing procedure to end up.
- Launch the Unreal Engine of the target version. In the Plugins panel, you will see the iClone Live Link item in the Installed node.
- Activate the Enabled check box and restart the Unreal Engine.
- You will see the iClone Live Link button shown on the toolbar, which implies that the plug-in has been successfully installed.
