Using Start Node
The Start Node serves as the entry point for all Motion Planning script flows.
  • Adding Start Node: Right-click any empty area within the MP Node Graph viewport and pick the Start sub-node from the menu.
  • Loop: Determines whether the entire subsequent Motion Planning Graph should restart upon completion.
    • Select a Start node and toggle the Loop setting within the Attributes panel.
    • Alternatively, you can enable or disable this feature directly via the checkbox on the node itself.
  • Multiple Start nodes are supported to initiate different Motion Planning script sequences simultaneously.
