Saving and Loading Gear List
Since Motion LIVE plug-in are able to connect multiple motion capturing devices, aka gears, you can save the completed gear list to prevent from manually re-adding gears each time this plug-in is launched.
The benefit is when the gears are installed on an intranet for sharing the captured data, sharing the saved gear list file to a group of PC on which the Motion LIVE plugin is installed can save a lot of time from setting gear list one by one.
A. Saving Gear List
Launch Motion LIVE plug-in.
- In the Gear List section, manually connect this plug-in to the desired mocap devices (gears).
Click the Save Gear List button.
- Surf to a target directory to save the gear list in a file (in *.json format).
B. Loading Gear List
Create a new project. Apply a character.
Launch Motion LIVE.
- Click the Load Gear List button. Load a json file (*.json) saved by the method in previous section.
- You will see the device is now all added, which saves time from adding them one after one.
