Expression Calibration (New for v 1.1)
Applying facial calibrations enhances AccuFACE’s facial detection precision and captures finer expression details from the performer for the character model in iClone.
Neutral Face
Neutral Face calibration provides a clean starting point for AccuFACE to reference the performer's neutral facial expression.
Neutral expression on the performer (left) and the character model (right).
Before recording your facial performances it's highly recommended to calibrate at least the Neutral Face expression. The initial calibration data can sometimes be inaccurate, and by setting a neutral expression AccuFACE will refresh the data ensuring precise expressions during your performance.
Brow Raise, Brow Drop, Brow Inner Raise
By incorporating Brow Raise, Brow Drop, and Brow Inner Raise expression calibrations, you can achieve greater precision in eyebrow expressions allowing subtle emotional nuances from the performer to be clearly portrayed on the character in iClone.
- Brow Raise
Before the Brow Raise calibration.
After the Brow Raise calibration.
- Brow Drop
Before the Brow Drop calibration.
After the Brow Drop calibration.
- Brow Inner Raise
Before the Brow Inner Raise calibration.
After the Brow Inner Raise calibration.
Adjusting Brow Inner Raise
If the Brow Inner Raise expression lacks accurate or noticeable results, click the Adjust Brow Inner Raise button to manually fine-tune the inner and outer brow morphs to achieve the desired outcome.
Before using Adjust Brow Inner Raise.
After using Adjust Brow Inner Raise.
