Assets for Two-Way Operations (New for iClone V.8.3)
While iClone and Omniverse can be synchronized for editing via Live Sync, the bidirectional statuses vary based on the types of assets. Consult the tables below for more information:
- Motion, Viseme and Expression
Transform (TR)
Gesture
Motion Layer
Reach
Strength
Voice
Lips
Lip Options
Talking Style
Expression Strength
Export USD
Import USD
- Constraint
Look at
Look at Target
Look at Camera
Path Position
Path Offsets
Path Rotate
Link
Export USD
Import USD
- Material / Textures
Material
Material Settings
Texture UV
Texture Strength
Export USD
Import USD
- Miscellaneous
Visible
Sound
Morph
Spring
Auto Blink
Export USD
Import USD
Transform (TR)
Gesture
Motion Layer
Reach
Strength
Voice
Lips
Lip Options
Talking Style
Expression Strength
Live Sync to Omniverse
Transfer to Omniverse
Sync from Omniverse
- Constraint
Look at
Look at Target
Look at Camera
Path Position
Path Offsets
Path Rotate
Link
Sync from Omniverse
Material
Material Settings
Texture UV
Texture Strength
1 frame
1 frame
1 frame
1 frame
Sync from Omniverse
- Miscellaneous
Visible
Sound
Morph
Spring
Auto Blink
1 frame
Sync from Omniverse
- Transform / Animation Layer
RTS
Pivot
Rigid Body (Baked animation)
Cloth
Edit Animation Layer
Prop Puppet RTS
Export USD
Import USD
- Constraint
Look at Target
Look at Camera
Path Position
Path Offset Rotate
Path Offset Scale
Link
Export USD
Import USD
Material
Material Settings
(Opacity / Diffuse Color)Texture UV
Texture Strength
(Base Color / Opacity / Glow)Export USD
Import USD
- Miscellaneous
Visible
Sound
Vertex Animation
Morph
(with Bones)Spring
Export USD
Import USD
RTS
Pivot
Cloth
Prop Puppet RTS
Sync from Omniverse
- Constraint
Look at Target
Look at Camera
Path Position
Path Offset Rotate
Path Offset Scale
Link
Sync from Omniverse
Material
Material Settings
Texture Strength
(Base Color / Opacity / Glow)Live Sync to Omniverse
1 frame
1 frame
1 frame
1 frame
Sync from Omniverse
- Miscellaneous
Visible
Sound
Vertex Animation
Morph
(with Bones)Spring
1 frame
Sync from Omniverse
- Transform / Constraint
Transform
Look at
Path Position
Path Offset Rotate
Path Offset Scale
Link
Export USD
Import USD
- Camera Settings
Lens
DOF
Camera Switch
Exposure
Export USD
Import USD
Transform
Look At Target
Path Position
Path Offset Rotate
Path Offset Scale
Link
Sync from Omniverse
- Camera Settings
Lens
DOF
Camera Switch
Exposure
Sync from Omniverse
- Transform / Basic Settings
Transform
Active
Color
Multiplier
Shadow Color
Darken Strength
Volumetric Light
Export USD
Import USD
- Constraint
Look at
Path Position
Path Offset
Link
Export USD
Import USD
- Light Parameters
Range
Darkness
Angle
Falloff
Attenuation
Export USD
Import USD
Transform
Active
Color
Multiplier
Shadow Color
Darken Strength
Volumetric Light
Sync from Omniverse
- Constraint
Look at
Path Position
Path Offset
Link
Sync from Omniverse
- Light Parameters
Range
Darkness
Angle
Falloff
Attenuation
Sync from Omniverse
