Batch Importing Custom Contents as Pack in Smart Gallery
Not only can you import custom contents one after another, you can also batch convert them as a custom pack for Smart Gallery.
- Open Smart Gallery.
- Click the Menu button at the top right corner of the panel.
- Choose the Import Custom Content command from the menu.
- Browse and pick your desired folder in which the custom contents are stored (in this case, the entire Character Creator 3 Custom library). Click the Select Folder button.
- The folder will become a pack in Smart Gallery. Type in the name for the pack and click the OK button.
- Smart Gallery starts to convert the contents into the new pack for a while.
- You will see the new pack shown under the Custom node in the Smart Gallery after the conversion is done.Note:
Notice that the thumbnail of the custom pack can be changed to another image.
- Double-click on the pack to open it, you can see all the custom contents are imported and categorized identically as the tree structure in the Content Manager.
