Customizing Categories by Tags
Although Character Creator and iClone have their own categories to group different contents; with the Tag feature, you can break the boundaries between different packs and re-group the objects.
- Pick one of the installed items in a Pack or in the Item View.
* Notice that you can pick one or more contents at this step. - Right-click on the item and choose Edit Tag command from the Context Menu.
- The Product Info panel shows and is switched to the Tag tab.
- Type in the desired tag string and click on the Add button.
- The tag with the custom string is add to this item.
- You can add more than one tags to an item with the same steps.
- With the same steps, you can add tags to any other items.
- You will see the tags shown under the Tag node in the left pane. The numbers after each tag string indicate the amount of the items that are grouped by the tags.
- Click on either of the tags to show the items in this group.
- Switch to the Pack View, the numbers shown indicates the numbers of the packs and items grouped with the tag.
- This number indicates the amount of packs that contains the items appended with the tag.
- This number indicates the total amount of items appended with the tag.
