Complete Technical Comparison Guide: Tripo vs. Hunyuan 3D
Tripo H3.1, Tripo P2.0, and Hunyuan V3.1 serve different 3D generation needs. Tripo H3.1 focuses on high-detail geometry, Tripo P2.0 prioritizes controllable polygon counts and native quad topology, while Hunyuan V3.1 offers high-quality 3D generation with support for up to eight input views. The best model depends on whether you prioritize visual fidelity, editable topology, or multi-view reconstruction.
Model Comparison
Tripo H3.1 |
Tripo P2.0 |
Hunyuan V3.1 |
Primary Focus |
High-detail 3D generation |
Low-poly mesh generation with native quad topology |
High-quality 3D generation |
Input Methods |
Text, single image, multi-view images |
Multi-View Input |
Supported |
Supported, up to 4 views |
Supported, up to 8 views |
Geometry Detail |
High; up to 2 million faces |
Optimized for low-poly output |
High; configurable up to 1.5 million faces through the documented API |
Native Quad Topology |
Supported through quad output options |
Core capability |
Smart topology is available as a separate processing capability |
Polygon Count Control |
Supported |
Core capability |
Supported, subject to generation mode |
PBR Textures |
Supported |
Depends on the selected workflow |
Supported |
Best Use Cases |
Detailed props, characters, and close-up assets |
Game assets, animation, and real-time applications |
Detailed assets and multi-view reconstruction |
Tripo H3.1 is designed for projects where geometry detail and visual fidelity are priorities.
Key Characteristics
- Generates high-detail meshes with up to 2 million faces.
- Supports text, single-image, and multi-view inputs.
- Supports PBR texture generation.
- Offers quad mesh output and smart low-poly options through supported settings.
Recommended Uses
- Detailed characters and props.
- Assets requiring close-up inspection.
- High-quality rendering and visualization.
- Projects where preserving fine geometric details is more important than minimizing polygon count.
Considerations
High-detail meshes can require more memory and processing resources. For real-time applications, additional optimization may be necessary to meet performance budgets.
Tripo P2.0 is designed to generate lightweight meshes with more structured topology, reducing the amount of manual retopology required.
Key Characteristics
- Generates native quad topology with clean edge flow.
- Supports controllable polygon counts.
- Supports triangle meshes from 500 to 50,000 faces and quad meshes from 500 to 25,000 faces in the documented Smart Mesh workflow.
- Supports multi-view input for more accurate shape reconstruction.
Recommended Uses
- Game-ready props and characters.
- Real-time rendering and interactive applications.
- Models intended for further editing, rigging, and animation.
- Projects with strict polygon budgets.
Considerations
Tripo P2.0 prioritizes efficient topology rather than maximum geometric detail. Small surface features may be simplified, so it may not be the best choice when intricate geometry must be preserved.
Hunyuan V3.1 focuses on high-quality 3D generation and supports a wider range of input views for reconstructing complex objects.
Key Characteristics
- Supports text-to-3D and image-to-3D generation.
- Supports up to eight input views.
- Provides configurable geometry output, with a documented API face-count range of 3,000 to 1.5 million.
- Offers separate Smart Topology processing for generating lower-poly meshes.
Recommended Uses
- Assets with multiple reference views.
- Projects requiring detailed shape reconstruction.
- General-purpose 3D asset generation.
- Workflows that combine high-quality generation with separate topology optimization.
Considerations
The available polygon controls and topology options depend on the generation mode. In the documented API, the 3.1 model does not support the LowPoly or Sketch generation parameters. Smart Topology is a separate processing workflow rather than an equivalent native quad-generation mode.
Project Requirement |
Recommended Model |
Reason |
Maximum geometric detail |
Tripo H3.1 |
Supports high-detail geometry up to 2 million faces |
Native quad topology and polygon control |
Tripo P2.0 |
Designed for structured, editable low-poly meshes |
Reconstruction using up to eight reference views |
Hunyuan V3.1 |
Supports up to eight input views |
High-detail asset that will later be optimized |
Tripo H3.1 |
Provides a detailed source mesh for downstream optimization |
Lightweight assets for real-time applications |
Tripo P2.0 |
Prioritizes controlled polygon counts and structured topology |
High-quality generation with separate topology optimization |
Hunyuan V3.1 |
Supports high-quality generation and a separate Smart Topology workflow |
Conclusion
Choose Tripo H3.1 when geometric detail is the priority, Tripo P2.0 when editable topology and polygon control matter most, and Hunyuan V3.1 when high-quality generation and multi-view reconstruction fit your workflow.
The final choice should also consider the generated model's shape accuracy, surface details, topology, textures, and the amount of cleanup required for your intended application.
