Changing the Layer Order of Sprites
After creating a prop with multiple sprites, you may adjust the sprite layer order in a compound prop with the Composer. You may arrange the visual logic of the prop as seen below.
Before adjustment
After adjustment
  1. Select a compound prop. Click the Composer button to enter the Composer Mode.
  2. Open the Layer Manager (Shortcut: F6).
  3. Select one of the layer.
  4. Drag and drop the layer up or down to re-order the layers. You will see a red line indicating the relocation of the dragged layer.
  5. You will be able to instantly see the changes inside the working area.
Did this article help you?
