G2 Head with Multiple Angles
The default G2 (generation 2) heads are created by CrazyTalk Animator Version 2 or above.
It is designed to have 10 angles in order to have the character face to different direction when you turn the character. The thumbnails of this type of heads will be marked with G2 at the corner as shown below.
However, if the head is converted from the G1 head, then CrazyTalk Animator Version 2 or above only inserts the G1 head into 10 angles, which causes the character's heads looks the same even if you turn the character to different directions.
