Loading Props from the Library
In Cartoon Animator'sStage Mode, you will find many prepared props inside the library. You may build great scenes by applying any of these multiple props.
- Create a new project.
In Stage Mode,
go to the Prop content folder in the Scene tab of the Content Manager and apply a template.
If you apply the prop by drag-and-drop method, then the prop will generate where you drop it.
If you apply a prop by double-clicking on it, or by clicking the
Apply button under the
Content Manager, the prop will then be put in the center of the scene.
