Using Pose Mode - FK and IK
In the Pose mode, you may adjust the limbs with FK
(Forward Kinematics) and IK (Inverse Kinematics)
methods. You can do this in order to give characters a general pose, or you can
slightly modify individual body parts in Body mode.
Using FK and IK
Select a character and click the 2D Motion Key Editor button.
Pick a Hand. You will see two concentric circles for
use with the FK method.
Drag the outer circle to rotate the hand, and the geared body, in an opposite direction.
Drag the inner circle to rotate the hand, and the geared body, in the same direction.
Pick a Leg. Drag the cross arrow inside the circle in order to use the IK method to
relocate the feet.
If you want the joints of the legs to be in a correctly angled, then you need to drag the
outer circle to form the angle first.
Pick the Body. Drag the cross arrow to move the pelvis of the character. This is easy when wanting the character
bend his/her knees.
