Introducing the Face Key Editor
( Watch Tutorial - Face Key Editing Basics )
( Watch Tutorial - Face Key Editor Enhancements )
The face Key editor facilitates setting or modifying keys in the Head, Face or Eyes tracks by using a more intuitive and interactive interface. To bring up the Face Key Editor, you may:
Select the character,
then click the
Face Key Editor button.
- Select the character, then press the Ctrl + K combination keys on the keyboard.
- Double-click on the desired key in the Head, Face or Eyes tracks to edit the existing key.
- Double-click anywhere in the Head, Face or Eyes tracks to initiate a new key.
The Face Key Editor is divided into four tabs: Morph, Template, Transform and Deform.
1. Clear Selection |
Deselect all features. |
Select to rotate / tilt the head. |
Select to highlight the desired features and convert the changes into keys. |
4. Default Key |
Click to set keys and neutralizes all adjustments made to facial features. |
5. Detail Settings |
Click to open the Detail Settings panel to adjust facial features with sliders. Please refer to the Detail Settings panel section in this page for more information. |
1. Expression Style |
Use the drop-down list to switch to a different expression template library. |
2. Expression |
Drag the slider to decide the strength of the applied expression template. |
3. Detail Settings |
Drag the sliders in this pane to set a key to the individual facial offset features. |
2. Expression |
3. Reset |
Click this button to reset the sliders to their initial status. |
The amount of eyes and mouth sliders variees in accordance with the modes, sprite or smooth, set in the Composer Mode.
- Sprite mode:
- Eye: 18
- Mouth: 23
- Eye: 18
- Smooth Mode:
- Eye: 12
- Mouth: 11
- Eye: 12
(For Sprite-based head only)
Select to highlight the desired features and transform the selected facial features. |
2. Reset Sprite |
Reset the transformation data of the selected facial feature. |
3. Reset All |
Reset the transformation data for all facial features. |
4. Default Pose |
Reset the transformation and deform data for all facial features. |
2. Reset Sprite |
Reset the deform data of the selected facial feature. |
3. Reset All |
Reset the deform data for all facial features. |
4. Default Pose |
