Applying Elastic Motions to Props
Usually, you create prop animations by mean of the key-frame-animation method.
Instead of that, Cartoon Animator provides libraries in which well pre-made Elastic Motion templates are ready for applying.
Most common animations can be found in the libraries and you just need to apply them to create lively animations for props.
( Watch Tutorial - Intro to Elastic Motions )
( Watch Tutorial - Combining Elastic Motions )
- Apply a prop.
Switch the Content Manager to the Elastic Motion >> Template tab >> ElasticMotion Template >> 1_Entrance.
Drag and drop one of the desired templates onto the prop to create an entrance animation.
The prop will then instantly perform the entrance animation of the template. -
Switch to the 2_Emphasis library and apply another template to the prop.
You will see the prop performing animation where it is. -
Switch to the 3_Exit library and apply another template to the prop.
The prop will then move out with the animation of the template. - The prop's animation is thus created without spending a lot of time setting keys.
If you wish to adjust the applied elastic motions, then please follow the steps below:
- Select the prop that has been applied with elastic motions.
- Open the Timeline (Shortcut: F3) and expand the Motion track of the prop.
- Double-click on the motion clip highlighted in Green to open the Elastic Motion Editor.
Alternatively, right-click on the clip and select the Elastic Motion Editor item from the Pop-up menu. - Adjust the settings in the editor to fine-tune the elastic motion.
Note:
If you wish to edit the applied elastic motion, then please refer to the Introduction of Elastic Motion Panel section for more information.
