Preparing a Custom Sprite
You can load different types of media, videos or images to create a sprite. When a sprite contains a series of image or videos, then you may create Image Replacement Animations in Stage mode with setting keys.
![Closed](../../../../Skins/Default/Stylesheets/Images/transparent.gif)
In Stage Mode, click the
Create Media button on the Function Bar.
Click the Prop button in the Create Media panel.
Load multiple media files. A sprite with multiple media files will be created afterward.
If you want to create a sprite, or append more media onto an existing sprite, then you may use the two methods below:
- Sprite Editor in actor or Composer mode.
- Drag and Drop from media source folders.
The added media in the sprite are named Poses. Any sprite can have multiple poses so that you can use these pose to generate Sprite Animations.
- Character
Select an existing character.
Click the
Composer button on the Function Bar.
Select a body part (sprite).
click the
Sprite Editor button on the Function Bar. The Sprite Editor panel shows.
- You may click another body part without closing the Sprite Editor.
Click the Add New Sprite
button. Load one or more media files.
This body part is now a sprite with multiple poses. All the
poses are now listed in the panel.
The possible look of the body part
Note:
If you want to create a character that is able to perform 3D dimensional motions, then you need to add up to 10 angles for the poses. Please refer to the sections below for more information:
- Prop
Select an existing prop.
Click the
Click the
Sprite Editor button on the Functional Tool Bar. The Sprite Editor panel shows.
button in the Sprite Editor panel. Load one or more media files.
This sprite is now appended with multiple media files. All the media files are now listed in the panel.
Different possibilities for a prop
Note:
The elements of a sprite can be media files in different formats:
- Image: *.jpg, *.bmp, *.gif, *.png, *.tga.
- Video: *.avi, *.wmv, *.rm, *.rmvb, *.mpg, *.mpeg, *.mpe, *.mp4, *.asf, *.asx, *.wm, *.flv, *.mov, *.swf
- Reallusion Specific Format: *.popVideo
You may select a video file and click the Preview
button to preview the results.
Select an element thumbnail in the list.
Click the Replace Current Sprite
button to load a new file that will replace the selected one.
- Select an element thumbnail in the list and press the Delete key to remove the element from the list.
- No matter which media file is selected from the list in the Composer Mode, the sprite will always shows the first one in the Stage Mode.
- Creating a Prop with Multiple Media
Select multiple media files from the source folder in Stage Mode.
Drag and drop into the working area of Cartoon Animator.
A new sprite prop containing several media files is
generated.
- Appending Media to a Sprite
Select a character or a prop. Switch to the Composer mode.
Select single or multiple image files in the source folder.
Drag and drop onto the target sprite in the working area of Cartoon Animator.
Pick the sprite and click the
Sprite Editor button. The media will then be converted into the poses of the sprite.
Note:
When you want to replace poses (of a character's facial features or body parts) or elements (of props) with prepared bitmap-based or vector-based files by using the buttons at the bottom of the Sprite Editor panel, you may need to follow the steps below.
This method replaces only one element in the sprite of a prop; and a single angle pose for a character's facial features or body parts.
Select an object (prop or character) and enter the Composer Mode.
Prop in Composer Mode
Character in Composer Mode
Pick a sprite and open the Sprite Editor.
Select the element (for prop) or one of the poses (if there are multiple poses for the character).
The element of the prop is selected
The pose of a character's body part is selected
Click the Replace Current Sprite button (for prop) or the down
arrow >> Replace Current Angle (for character) at the bottom of the panel.
Click the Replace Current Angle button (for props)
Click the down arrow besides the Replace Current Angle (for characters) and select the Replace Current Angle command
Load a prepared file to replace the current one.
Note:
For the character, you are able to open the Angle Table, where you'll be able to see that only the content in the current angle slot has been replaced.
Use this method to replace character poses that look identical at all 10 angle profiles.
Select a character and enter the Composer Mode.
Select one of the poses (if there are multiple poses for the character).
- Click the down arrow beside the button at the bottom of the panel.
Choose the Replace Full Angle command.
Load a prepared file to replace every angle of this pose with the
loaded file.
Open the Angle Table and you will see every angle is replaced
with the newly-loaded file.
![Back to Top](../../Images/UI_Icons/top.png)
