G1 Body with Single Angle
The G1 (generation 1) body can be found and used in CrazyTalk Animator Version 1.
It is designed to face either Front or Side view (implied by the directions of the left feet of the character). There is no way to change the direction of this type of characters in CrazyTalk Animator Version 1.
If you apply this type of body to CrazyTalk Animator Version 2, or above, then the body will be put into the 10 different slot angles. Therefore, no matter which angle you turn the character, the body will always look the same. Please refer to the G2 Body with Single Angles section for more information.
Most of the G1 Sprite-based bodies of this type can be seen in the Content Library of CrazyTalk Animator version 2 or above. The bodies have been converted, even if they have been marked G1 at the corner of their thumbnails.
