Creating Custom Teeth
You may create your own character's teeth by importing a custom teeth image:
You must apply a teeth template from the teeth gallery first.
Click the Teeth Settings
button on the Create Face Bar to access the Teeth Settings panel.
- Choose the Teeth radio button.
In the Diffuse channel, click the Import button to load the texture image for the virtual teeth.
(jpg, bmp, png are supported, 256 x 166 pixels recommended)
The teeth image, in PNG format, containing alpha channel.
(The part displayed in the check board pattern area)Note:
- If you import an image in 32-bit BMP, then the black part in the image will be converted into the alpha channel. If your image is not in 32-bit BMP or PNG, then you must load the grayscale image to decide the display area of the teeth.
The part with alpha channel will be transparent and it will reveal the inside mouth color.
- In the Transform section, fine tuning the position and orientation of the teeth to match the angle of the mouth.
In the Color section, adjust the color of the teeth.
Before adjusting the teeth color
After adjusting the teeth color
![Back to Top](../../../Images/UI_Icons/top.png)
