Teeth
After you apply a virtual mouth, you may then modify the location, orientation and the color of the teeth inside the mouth.
![Closed](../../../../../Skins/Default/Stylesheets/Images/transparent.gif)
Click the Teeth Settings
button on the Create Face Bar to access the Teeth Settings panel.
To set the size of the teeth, use the Scale
feature. Adjust the X/Y values to adjust the width and height of the teeth.
Oversized Teeth
Scaled Teeth
To specify the position of the teeth in the mouth, use the Move
parameters. Adjust the X/Y values to relocate the teeth.
Location offset
Location adjusted
Use the Rotate
value to decide the orientation of the teeth and match the angle of the mouth.
Angle not fixed
Angle fixed
You can change the teeth color in the Color section. Move the Brightness, Contrast, Hue, and Saturation sliders to adjust the teeth color. Alternatively, enter a number in the boxes next to the slider bar to change the parameter value.
Yellow teeth |
Teeth whitened |
![Back to Top](../../../Images/UI_Icons/top.png)
