The Default Key helps you retrieve the neutral status of
all facial features in a model. You may use it to set neutral keys to all facial features or to retrieve the initial status of them.
Each time you want to remove all facial expressions and go back to the neutral expression state, or when you want to
remove the transformation keys (rotation, location, scale) and go back to the initial status, then follow the steps below:
Double-click on the desired Face key (in the timeline) to bring up the
Face Key Editor panel. Please note
that the key already contains offset data.
Select any feature in the Face Key Editor and drag in the interactive area to modify the
model's features.
Click the Default Key button and the offset data will be cleared. The model will then turn back to its
neutral appearance and the original key will be replaced by a neutral one.
