Max Texture Size
The Max Texture Size can be used to determine the largest size allowable for the textures for the exported iAvatar.
- The texture whose original size exceeds the Max Texture Size will be downsized to the Max Texture Size.
The texture whose original size is under the Max Texture Size
will be left untouched.
- You can still determine the texture size for each different object from the drop-down list.
However, the maximum setting in the list are still limited under the Max Texture Size.
