Flipping the Normal
At times there may be missing faces on a model due to flawed normals direction. This can be fixed by using the Flip function to invert the faces inside out.
Flipping Normal
Load an object (a pair of shoes in this case). Notice the left shoe is
flipped inside out.
Select the normal-flipped object.
- Open the Edit Normals panel via Mesh > Edit Normals.
Click the Invert button in the panel.
Note- See Unifying the Normal if some of the faces fail to render due to holes or cavities on the surface of the objects.
