Applying Body Template
In Character Creator, you are able to freely change the body shape of the character by means of embedded templates or by manually adjusting the provided parameters.
Changing Body Shapes with Templates
Launch Character Creator, by default, there will be a nude default character.
- Switch the Content Manager to Actor > Body Morph > CC3+ library.
Note:
There are two method to switch to desired library:
- Tree View: If you only want to switch between different libraries
under same categories, then use the Tree View in the Content Manager.
- Path Field: In addition to the Tree View, you may also change to different
libraries under the same category by clicking the arrow button in the Path Field.
Apply either one of the template (in this case, the Strong Male) by double-clicking on the template.
The character will turn to the desired appearance as the
template shows.
Getting Content Pack
If you want to have more options for the body appearances of the character, then go to the
official web site for purchasing the content pack.
