Editing Elements
When you want to transform or adjust the elements of an object, including the hair, clothes, accessories, shoes and gloves, you can use the Edit Mesh >> Element function.
Editing Elements
- Select the object (accessory, in this case) you want to edit.
- Go to the Modify panel >> Edit tab >> Modify section.
Press down the Edit Mesh button and switch to the Element mode.
- Click to select the element of the object.
Switch to either of the transform tools (in this case, the Scale tool).
Scale the element.
- Keep on editing the element with the transform tools (move, rotate and scale).
Optionally edit another element with the same steps. - Optionally edit the elements with vertex mode .
- Leave the Edit Mesh mode. The object's shape is then changed.
![Back to Top](../../../Resources/Images/top.png)
