Importing Methods
There are several methods for importing FBX or OBJ files into Character Creator for creating custom characters or props.
- OBJ
If you drag and drop an OBJ file into the 3D viewport, it will instantly convert into a prop without any further steps.
- FBX
- Drag and drop an FBX file into the 3D viewport.
- You will see the Import FBX panel displayed for choosing the target object you want to create.
- If you click the Character button, then the Import Fbx panel pops up.
- Click either one of the button to proceed the rest of the conversion steps.
- Go to the Create menu and execute the Create Character or Prop command.
- For the Create Character command, browse and select a desired FBX file and click the Open button.
System starts the auto-conversion process.
Click OK to create a Humanoid character or click Cancel to create a Creature character.
You can convert it to Humanoid character using the Characterization feature afterward. - For the Prop command, simply browse and select a desired OBJ or FBX file and click the Open button.
The file will be converted into a prop instantly. You can convert it to Creature or Humanoid characters afterward.
Click an empty space in the 3D viewport. You can import character or prop through the buttons in the Modify panel.
- For the Create Character button, browse and select a desired FBX file and click the Open button.
You can convert it to Humanoid character using the Characterization feature afterward. - For the Create Prop button, simply browse and select a desired OBJ or FBX file and click the Open button.
The file will be converted into a prop instantly. You can convert it to Creature or Humanoid character afterward.
