Updating Textures in Character Creator
Be sure to reload the exported avatar or project after the materials have been adjusted, so that the project will update with the correct materials.
- Use either method below to update the textures in Character Creator:
- Toolbar > Substance > Update Textures from Substance Painter.
- Menu > File Update Textures from Substance Painter.
- Once activated, select the Substance Painter export folder to update the textures.
- If any of the material folders fail to load, a warning message will pop up. You will have to manually check for non-matching material names or missing objects.
- Regardless of non-matching materials yielding error warnings, other materials inline with matching criteria, will still be updated.
