Subsurface Scattering Related Textures
Transmission Map
The grayscale transmission map defines areas of the body where light passes through.
  • Body: Completely black: no transmission effect at all.
  • Arms: The fingers have some light transmission.
    When viewed from the underside of the hand; one can see light passing through the fingers.
  • Legs: The toes have some light transmission.
    When you view the dark side of the feet, you can see the light passing through the toes.
  • Nails: The nails will also be translucent.
    When you view from the dark side, you can see the lights passing through the nails on the toes and fingers.
SSS Map
The SSS Map determines the body parts to have the SSS reflection effect. This map provides the moisture and the tissues under the skin.
  • Body: The body reveals the color of the tissues under skin by means of this texture.
    You can see the tissues color reflects on the skin.
    SSS Map in pure black
    Customized SSS Map
  • Arms: The arms and hands reveal the color of the tissues under skin by means of this texture of white, by default.
    You can see the tissues color reflecting on the skin.
    SSS Map in pure white (default)
Did this article help you?
