Drag
The Drag setting is effective for singular surfaces; and they only have an obvious effect when the surface moves. The component of force parallel to the oncoming flow is called Drag. It will essentially pull the soft-cloth towards the opposite direction (D) of the initial momentum (M).
Drag = 0.20
Weak dragging force.
Drag = 1.00
Strong dragging force.
You can then mix-up this setting with a Wind force to produce a turbulent and extended soft-cloth.
