Animated IBL with Keys
IBL Key can open up many possibilities, depending on the type of project, one can use different IBL images to achieve better visual results.
- Click on Visual panel > Atmosphere tab > Image Based Lighting section > Add New IBL button to create a new IBL clip.
Adding a new IBL clip will duplicate the previous IBL track.
Note:
- You may choose to replace the IBL for the clip by picking the desired track and then replacing the source HDRI.
- On the front of the IBL clip is a blending region that intersects with the previous IBL clip, usage of this blend region is the same as a Motion Clip.
