The User Interface Introduction of IBL
IBL Images
2 |
Sky Settings
- Visualize Sky: These two buttons are used to show / hide the Sky entity.
- Sync Sky: By activating the Image and Rotation boxes, you are able to synchronously adjust the IBL and Sky image or angle.
- Sky Softness: This slider can blur the Sky while keep the diffuse image of the sky untouched.
- Sky Setting: Click this button to open the Modify panel > Sky section for further adjustments.
3 |
Baking IBL
- Bake Image Size: Set the desired resolution for the image after baking.
- Auto Load HDRI: Activate this box to automatically load the baked IBL images once it has finished calculating.
- Bake IBL: Bakes an HDRI image in .hdr format from the pivot of the selected object in the scene.
4 |
IBL Transformation
To transform the IBL sphere.
- Rotate IBL: Click this button to toggle the IBL rotation gizmo On / Off; the keyboard shortcut is Shift + I.
- Transformation Field: In addition to use the gizmo for transforming the IBL sphere, you are able to use these fields to type the desired values.
- Reset: Click this button to retrieve the initial transformation values of the IBL sphere.
Did this article help you?
Feedback received! Thank you.
