Aligning Orientation to Target Object
The Align to panel lets you align objects by position and orientation.
Prepare a new project with several objects.
- Select one of the objects.
- Click the Align to button on
the General Toolbar.
- When the cursor changes to a picker, select an object for target orientation.
- Activate the XYZ check box in the Align to panel, click the OK button.
- The object's direction will be aligned to the target object.
- Multi-select the other objects within the scene.
- Repeat the same steps from step 3 to 5.
- These objects will be reoriented as well.
- You can also use the Align to X, Y or Z to
move the selected objects to the position of the target object.
