Advanced Water Parameters - Reflection
You may want to change the way water reflects more of the surrounding environment to create a different look.
Reflection above the Water Surface
  1. Go to the Advanced Water Parameters section in the Modify panel.
  2. Scroll up to the Reflection parameters.
  3. If you intend to modify the reflection strength above the water surface, drag the Above Surface Strength slider.
    The higher the value, the stronger the reflection shows on the water.
  4. Increase the Blur value so the reflection becomes less clear.
    Reflection = 10
    Reflection = 100
    Blur = 2
Reflection under the Water Surface
You may follow the same steps as above to adjust the reflection under the water surface. This time use the Under Water Strength slider.
Reflection = 10
Reflection = 100
Blur = 2
