Blend Map
The Blend Map parameters are used to adjust the Brightness and Saturation of the Base Color texture in the Texture Settings section. The adjustments leave the original texture untouched while you adjust the skin tone.
  • Base Color Blend Map Brightness: This value adjusts the brightness of the skin texture.
    Base Color Blend Map Brightness = 0.000 (default)
    Base Color Blend Map Brightness = 0.100
  • Base Color Blend Map Saturation: You can use this slider to adjust the color saturation of the skin texture.
    Base Color Blend Map Saturation = 0.000
    Base Color Blend Map Saturation = 0.200
