New Contents for SSS Shader
In iClone v7.8 or later version, there are materials templates with SSS Shader (Sub-surface Scattering shader) prepared for you to quickly apply SSS effect to desired objects (Hair, Prop, Accessory, Cloth, G1, Game Base and Non-Standard Characters).
You can find them in the Material > SSS library.
The semi-transparent effects on object can be seen as the following illustrations.
Prop applied with PBR shader |
Props applied with SSS shader |
