Micro Normal
The Micro Normal is an additional normal map on top of the regular Normal map in the Texture section. It is used for depicting the fine lines and intricate details of a surface.
Surface with Normal map only |
Surface with Normal and Micro Normal maps |
You can find the settings for adjusting the Micro Normal map in the Micro Normal sub-section under the Shader Setting section in the Modify panel.
- Micro Normal Tiling: This value determines the tiling of the Normal Map on the entire body, arm, leg, or nail meshes.
Micro Normal Tiling = 32.000 (default)
Micro Normal Tiling = 2.000
- Micro Normal Strength: This setting carve the fine lines deeper or lighter on the surface.
Micro Normal Strength = 0.500 (Default)
Micro Normal Strength = 1.500
![Back to Top](../../../../Resources/Images/top.png)
