DOF Track
Follow the steps below to set keys on the DOF track to create DOF animation. Please read the DOF (Depth of Field) section for more information.
- Select a camera from the Scene Manager. Go to the desired frame you want to set the DOF key.
- In the Modify panel, scroll to the Depth of Field section.
Check the Activate box to enable this feature. You may
set the distance manually or use the Pick Target
button to let iClone select the correct value.
Go to another frame and change the DOF value.
- iClone generates the transition effect between the two keys.
The transition effect should look like the following illustrations.
