IBL Tracks
You can set IBL keys in order to have different IBL effects, such as Strength and Translation, with the elapse of time.
- Create a project with props, sky and IBL.
- Playback to view the animation. The IBL effect remains the same throughout the entire project.
- Go to the specific frame where you want to change the IBL settings.
- Open the Visual panel (Shortcut: F7), in the Image Base Lighting section, adjust the only one key-able parameters, Strength.
The IBL Stength will be changed.
A new key will be auto-added into the IBL Strength track on the timeline.
- Repeat the steps on different time.
- Playback to view the result.
- You can also set IBL Transform keys by adjusting the controls in the IBL Transform section.
- The keys can be found on the IBL Transform track.
