The Correlations among Tags, Actors and Motions (New for v. 8.4)
The tag system for Crowd Generator can be used to adequately match the actors and the motions, which lets the actors to automatically perform different motions for Motion Director. The crowd can then move in randomized fashion.
How iClone matches actors and motions:
- If both the actor and motion possess Age tags, then compare the tags and go to the next step. Otherwise, skip to step 3.
- If the motion's Age tag can be found in the actor's tags, then go to proceed to step 3. Otherwise, they mismatch.
- If both the actor and motion possessed Gender tags, then compare the tags and go to the next step. Otherwise, skip to step 5.
- If the motion's Gender tag can be found in the actor's tags, then go to step 5. Otherwise, they mismatch.
- If the motion's Custom tags can be found in the actor's tags, then they match and the motion will be applied to the actor. Otherwise, they mismatch.
