The Actor, iProp and iAcc
Once you have applied any iAcc, which is embedded with human centric scripts to the actor or applied any human centric script-embedded iProp into the scene, the actor can control the actions of the objects or instantly reflect the performance embedded in the objects from the right-click menu. The right-click menu changes depending on what is attached to the actor. Once you have applied an iAcc (accessory) to the actor, you may see the difference in the actor's right-click menu.
iAcc to Actor
  1. Let's see what happens to the right-click menu before we drag anything to the actor.
    Notice in the perform section, the actor only holds fewer motions.
  2. Drag an iAcc to the actor.
  3. Right-click on the actor again to see the difference.
  4. The actor's performance has increased by adding the actions embedded in the Boxing Gloves.
Actor to iProp
  1. Add a bed to the scene.
  2. Click the desired actor for controlling the actions.
  3. Right-click on the bed, and select a command for the actor to perform with.
