The Default Pose for CC Characters are
set, by default, to a T pose. However, if you want their default pose to be
different then you can designate a custom default pose to the CC
Characters.
Nevertheless, you can change the default poses for the G5
and G6 characters as well.
The Default Pose of the embedded CC male -
Christian.
The Default Pose of the embedded CC female -
Natalie.
Creating Custom Default Pose
Select a character (in this case, a CC Character from
iClone Character Creator with T
pose only).
Click the Animation >> Edit Motion Layer
command from the main menu bar.
Adjust the pose of the character with the controls in the panel.
Click the Set as Default button in the panel.
Exit the panel.
Add this character to the Custom library.
Each time you apply this new character, the default pose will be the one you designed in the previous steps.
