By using the Edit Path function it is possible to enhance and modify a path to create any imaginable shape or fine-tune its positioning in the scene.
Create any shapes for the object to follow.
Select the path and click the Edit Path button to go into path editing mode.
Right-click on the path to Add or Delete Control Points.
Add |
Delete |
Press the Ctrl key to select multiple points for deletion.
Select |
Delete |
You can also use the
Selection
tool to select multilpe control points at once.
While a control point is selected you can use the
Move
and Rotation
tools to set its transform data.
Move |
Rotate |
Note:
