The Dope Sheet track is a very unique track. You can not set keys in it nor can you add any clips to it. However, you can directly perform key editing on the master track without having trouble clicking on every individual track to find the specific keys you created, which makes observation and editing much easier.
The dope sheet track is actually a track that displays keys representing all the other keys within the other tracks of the same object.
A character's dope sheet track and dope sheet keys. |
These keys represent the data in different tracks. |
Note: |
Editing the dope sheet key (in this case, moving). |
The data that is represented by the dope sheet key will be edited as well. |
Edit the dope sheet keys (in this case, to delete the dope sheet keys that are spanning different objects & tracks). |
The data that is represented by the dope sheet keys will be edited as well. |
