After a constraint is applied to a rigid body, you are able to set limits to the constraint's position and the angle, which ensures the constrained rigid body can move or roll along within a specified distance or range.
You can use the controls in the Move section to limit the constraint to move along a specific Local Axis within a certain distance range.
Lock:
Press this button down to stop the constraint from moving along the axis you specified.
The Local X axis is locked. The constraint can not move along this axis. |
The Local Y axis is locked. The constraint can not move along this axis. |
The Local Z axis is locked. The constraint can not move along this axis. |
Limit:
Press this button down to determine the moving distance along the specific axis.
A range is set to the Local X axis. The constraint can only move along this axis within this range. |
A range is set to the Local Y axis. The constraint can only move along this axis within this range. |
A range is set to the Local Z axis. The constraint can only move along this axis within this range. |
Note: |
Free:
Press this button down and the constraint can
infinitely move along the specific axis.
The Local X axis is set free. The constraint can infinitely move along this axis. |
The Local Y axis is set free. The constraint can infinitely move along this axis. |
The Local Z axis is set free. The constraint can infinitely move along this axis. |
Note: |
You may use the controls in the Rotation section to limit the constraint to rotate along a specific Local Axis within a certain angular range.
Lock:
Press this button down to stop the constraint from rotating along the axis you specified.
The Local X axis is locked. The constraint can not rotate along this axis. |
The Local Y axis is locked. The constraint can not rotate along this axis. |
The Local Z axis is locked. The constraint can not rotate along this axis. |
Limit:
Press this button down and enter the
Min and Max values to decide the
angular range of the rotation by the specific axis.
A range is set to the Local X axis. The constraint can only rotate along this axis within this range. |
A range is set to the Local Y axis. The constraint can only rotate along this axis within this range. |
A range is set to the Local Z axis. The constraint can only rotate along this axis within this range. |
Note: |
Free:
Press this button down and the constrained rigid body can freely rotate
along the specified axis.
The Local X axis is set free. The constraint can freely rotate along this axis. |
The Local Y axis is set free. The constraint can freely rotate along this axis. |
The Local Z axis is set free. The constraint can freely rotate along this axis. |
Note: |
