Since a CloneBone actor behaves exactly the same as the standard actors, you may modify its motion the same way as with normal human actors.
Pick the CloneBone actor.
Go to the Animation tab of the Modify panel. Click the Edit Motion Layer button.
Select
or
tools to utilize the IK or FK method to
modify the motion of the CloneBone actor.
Note: |
You may directly pick the specific bone node without being hindered by the props or accessories attached to it when you are using IK or FK methods. Please refer to the Using the Edit Motion Layer Panel section for more information. |
