After you have installed the iClone Indigo Render Plug-in, you will see
a new toolbar shown on the top docking area with four Indigo related buttons.
1 |
Render Scene |
To export the current scene and instantly start to render it with Indigo. |
2 |
Export Scene As |
To save the current scene as an Indigo supported scene file (*.igs) without starting rendering. |
3 |
Render Settings |
To show or hide the Render Settings panel. |
4 |
Toolbar |
To show or hide the Indigo Render Plug-in
Toolbar. |
5 |
Online Manual |
Opens the iClone Indigo Render Plug-in online manual. |
6 |
About iClone Indigo Render |
To show or hide the information window for the iClone Indigo Render Plug-in. |
7 |
Render Selected Object |
To only export the selected objects and instantly start to render them with Indigo. |
8 |
Indigo Program Path |
To show the path in which you installed the Indigo application. By default, it is installed in: C:\Program Files\Indigo RT\ |
9 |
Indigo Material Path |
To show the path in which Indigo stores all the downloaded material presets. By default, it is installed in: C:\Users\Shihfei\AppData\Roaming\Indigo Renderer\materials\ |
