Play Bar
The play bar is used to control the real-time playback of iClone scenes.
Realtime/By Frame
Switch to Realtime or By Frame mode for simulating physics.
Play
To play back current project.
3
Jump to Start Frame
To jump to the cue in frame of the playback range or the start frame of the whole project.
4
Previous Frame
To jump one frame backward.
5
Next Frame
To jump one frame forward.
6
Jump to End Frame
To jump to the cue out frame of the playback range or the end frame of the whole project.
7
Loop On/Off
To toggle playback loop on/off.
8
Preview / Export Range Switch
To switch to the Preview or Export range modes from the context menu.
9
Vocal Volume
To adjust the volume of the sound effect.
10
Music Volume
To adjust the volume of the background music.
11
Current Time
To show the current time/frame.
12
Project Settings
Use the Project Settings panel to set the total length for the current project, select the time unit, adjust the volume of the sound, configure the physics settings, and modify the background color or load a background image.
13
Show Timeline
To evoke the Timeline (F3).
14
Mark In/Out of Playback/Export Range
Drag this mark to set the mark in/out frame for playback or exporting.
15
Play Head
Shows the current frame of the project. You may also drag it to any desired frame quickly.
16
Mark In / Out of Preview Range
Drag these markers to set the mark in / out frame for preview playback.
