Basic Usage of Bezier Handles
To change the shape of a path, you can either transform the control points belonging to the path, or by using the Bezier Handles without touching the control points.
  1. Create a path.
  2. Select the path and click the Edit Point button on the Modify panel to go into path edit mode.
    Alternatively, you can right-click on the path and choose Path >> Edit Path to enter the path edit mode.
  3. Click on the desired control point. By default, the Bezier Handles are shown bilaterally.
  4. Click on either one of the red boxes. The transform gizmo will show (if not, press Ctrl + Q to show it).
  5. Move the box with gizmo to modify the curve's direction.
  6. Drag the red box away from the control point to increase the curvature.
See Also:
