The Surfaces for Path
When creating path, you can determine to have the path to be created on the grid plane, the terrain or the sky.
Creating Paths on the Grid Plane (XY plane)
When you are creating a path on the grid, the path pointers will snap to the grid as you go.
- Press Ctrl+G to toggle visibility of the grid.
Click the Create >> Create Path command from the main menu bar.
First Control Point
Second Control Point
Third Control Point
You can click to position the control point and pull to extend the next control point.
- You may right-click or press ESC to exit.
Drawing on Terrain
When creating paths on terrain, the control points follow the height and angle of the terrain. Whereas the grid only remains on a flat surface.
First Point |
Second Point |
Third Point |
As you can see, the points snap right onto the surface's height once the pointer is positioned.
Drawing in the Sky
When creating paths in the sky, you create the path from the angle of the camera to the distance of 50m away from the camera.
Please do not create path both in the sky and on the terrain, you might get an unexpected result.
In order to get the best result, we suggest you to create a path on the terrain first, and then flip the path to place it in the sky.
