Transition Curves in Tracks
In iClone, you are able to set keys or add clips into different tracks. Interpolations can be customized between different curves so that the transition speeds between two adjacent keys, or clips, imitate the physical characteristics of how the object would move in the real world.
Set the Transition Curve
  1. In the target track of the timeline, set two keys (take the Transform track as an example).
  2. Right-click on the Later one. Select an item from the Transition Curve entry in the menu.
    The transition curve will then be generated between these two keys only.
The Curve options have increased from 6 to 16 also accessible via the context menu, however, in the form an independent window. Each Transition Type can be previewed in the view-port simply by selecting it in the floating window, making it more intuitive and convenient.
Transition Curve Panel and Four Basic Curve Types
Ease In
Ease Out
Ease In & Out
Pause and Move
Second Row of Curve Presets
Gain momentum before Move
Damping
Gain momentum and Damp
Stutter Start
Third Row of Curve Presets
End in a Bounce
Stuttering Start and End
Elastic Start and Sudden End
Sudden Start with Elastic end
Fourth Row of Curve Presets
Elastic Start and End
Step
Linear
