Using AO Effect
For adding the AO effect onto an object, please follow the steps below:
  1. Prepare a project with objects.
  2. In the Visual panel > Atmosphere tab > Ambient Occlusion section, activate the Ambient Occlusion box.
  3. Set the blending strength of the AO on the scene (The degree of blending for Visualize AO) by adjusting the Blend Intensity slider.
  4. Change the Range to determine the size of the range that will detects the surfaces intersect into the range for generating AO.
  5. Adjust the Sharpness to determine the edge sharpness for the AO effect.
    The Sharpness is increased from 0 to 50.
  6. Adjust the Bias to change the offset of the AO result.
  7. Switch back to Apply AO mode to view the result.
